Innovator
Posts: 12304 Location: Nashville 102 Days Since Last Explosion |
Innovator
chandlerman wrote: That's a Normally Closed switch. Used in Balanced AC systems where it shorts to ground by default, so you open it to cause power to flow to the light. |
Posts: 5153 Location: Veria, Greece |
SaFiS wrote: If the push plunger is fully out in the pic, it's a shutter… |
Posts: 2415 Location: S.Salem, NY |
It's for a DC circuit where when the pedal is up the circuit is open. Pressing the pedal releases the plunger and the circuit is closed.
Moto64 wrote: It's for a DC circuit where when the pedal is up the circuit is open. Pressing the pedal releases the plunger and the circuit is closed. |
Innovator
Innovator
hibbert wrote: Thanks SaFIS and yes the push plunger is fully out. |
chandlerman wrote: Damnit...got it backwards...time to go delete my previous wrong answer. |
Innovator
Innovator
hibbert wrote: Dang it CM1 but I still think you are partially correct seems like it's a normally closed switch and you have to move it to open if that's correct. Much appreciated I'm still confused slightly on the nomenclature but confident I need a shutter for replacement. Also, much like a clutch castle nut, the only time I'd ever encounter a shutter switch would be when I ripped it out along with the Balanced AC system it came with. |
chandlerman wrote: Yeah, I think of it in non-Vespa terms (Normally Open & Normally Closed), and then get backwards in my head on the whole "opener" or "shutter" thing. |
Moto64 wrote: It is backwards : Normal is with the pedal pressed. |
