Hi gang, was just wondering, on the stock 180 ss carb...what size jets did they originally come with? Thanks
Fab
Fab |
66 bluebadge,primavera,2x 74 rally,79 p200e 64 gl 306 2x 64 vbb
Posts: 80 |
Posts: 80 |
Jedihunter..
Thanks, i just came across the same info a few minutes earlier, thank you though. So i guess i do have all the original jets in the carb. I was trying to think if i cleaned out the Main jet, can't remember now. It's located below the top-half, of the carb? Took the bike out on a short ride today. Trying to get the carb settings adjusted. |
Posts: 80 |
Posts: 80 |
The main stack is under the air filter. I would pull them out and clean them just to know for sure.
Jedi, thanks. Yes I believe that's the Slow-Running and the Main. I will re-clean them again later. Overall, the bike runs well... i just find that if I'm coasting along and give more throttle, there is a slight "flat spot"?, and then continues to accelerate. In the flat spot, there is no bogging, or sputtering...if just feels like nothing is happening, then it picks up again.
I will reclean jets as i know there was a bit of stale gas in the tank when i refilled it. |
Posts: 2034 Location: S.Salem, NY |
Posts: 371 Location: George, South Africa |
I have rebuilt a 180 SS a couple of years ago, and the following jets were used:
Choke 60 Idle 50 AC 160 Mixer BE3 Main 118 |
Danie... did you have any issues running those jets? I believe i have the same jets as you, only thing I don't know where it is, is the main jet (120)? Where is it located? Not sure if i cleaned it....
Danie, sorry i'm not sure I understand... if i take off the air box, i have 2 tops of jets exposed... the smaller sized one is the Idle (50). Then next to it is the bigger one. If i take that out, the markings i see is
160(AC) BE3 (mixer) Where is the main at this point? Would you have a pic of where it is? Thanks Fab |
It is the pointed piece on the very bottom. You can pull it out of the mixer with some small pliers and a slight twist being carefully not to burr it up or contact the conical tip where the hole is. You should be able to make out the number stamped into it.
