@donpimpon avatar
vespa gtv 250
@donpimpon avatar
vespa gtv 250
hi
Recently i replaced the original variator of my Vespa GTV 250 with a Malossi Multivar 2000 variator (5111885)
In the same operation I replaced the cluth with a original Piaggio , the original Piaggio belt.
The Malossi Multivar 2000 kit comes with 16 and 14 gram rollers and White spring.
After instalo rollers, spring and belt i tried with 16 grams rollers but the scooter had no acceleration from zero and no maximum speed. Its si slowly!!
On the second attempt I tried the 14 grams rollers, and the scooter has more output and acceleration, more speed than with the 16 grams, but it doesn't convince me.
Should I try other weights?
12? 13 grams?
the rollers malossi kit are 20 x 17
Thanks for all
@crazycarl avatar
@crazycarl avatar
I have done this same upgrade and went with 12 gram rollers with good results.
@mike_holland avatar
GTS300 Super 2023 Beige
Back in March 2008 Scootering magazine published a comparison report on variators for the GTS250.They found the optimum roller weight for the Malossi was 12.5-13 grams, 13 grams being slightly better for high speeds. They also had the torque spring fitted that came with the variator.
@donpimpon avatar
vespa gtv 250
@donpimpon avatar
vespa gtv 250
thanks for the answers!
I bought 6 malosi rollers in 12.5 grams at the Malossi store and I will test the results Next week!
Can I mix 3 rollers of 12,5 grams and 3 of 14 grams? that result would give 13.25 grams
I will keep you informed of the progress
@crazycarl avatar
@crazycarl avatar
You can mix them, just be sure to alternate their placement in the variator.
@donpimpon avatar
vespa gtv 250
@donpimpon avatar
vespa gtv 250
Perfect!
Would I use the 3 original Piaggio washers?
Should any washer be changed?
BEST regards!! Thanks !!!
No. Over time, that can separate the brass bushing from the aluminum variator. Honda tried to engineer around this issue in the Foresight/Reflex, and came up with a variator that had ramps of different length, so the pressure would be even. Never used it again.
@donpimpon avatar
vespa gtv 250
@donpimpon avatar
vespa gtv 250
Finally i bought 12.5 and 13 gram rollers
I will try in a few days
gts 250 ie
gts 250 ie
Have you already tried the 12.5g rollers?
@donpimpon avatar
vespa gtv 250
@donpimpon avatar
vespa gtv 250
hi
I have tested rollers on Vespa gtv 250 with malassi multivar 2000 variator
The Malossi Multivar kit comes with 14 and 16 grams rollers and white spring.
The 16 grams rollers made the scooter very slow.
14 grams rollers better but worse than the original.
I have tried the 12.5 and 13 grams malossi rollers.
The scooter changes quite a bit compared to 14 and 16 grams.
Perhaps at 12.5 grams, the Vespa climbs better on hills and on flat land, but less output.
Straight line , 120 km/GPS and runnhills about 110/115 kms/h
Next week I will continue testing and I will tell you because i expected more difference compared to the original Piaggio
gts 250 ie
gts 250 ie
yo he comprado el mismo variador para una vespa gts 250 del 2006. ahora llevo el variador original con rodillos pulley. tengo los rodillos del variador malossi de 14g 16gr y de 13gr. los probaré y os contaré qué tal.
@donpimpon avatar
vespa gtv 250
@donpimpon avatar
vespa gtv 250
Tell us what weight of malossi multivar roller is best for you.
13 grams? 14? 16?
[ Time: 0.0093s ][ Queries: 3 (0.0031s) ][ live ][ 339 ][ ThingOne ]
