VNB5 Vespa
VNB5 Vespa
gentlemen,
I'm trying to install new wheel bearings in a 1964 VNB, is there a trick or tool that is needed to seat them in?
zooboyrick wrote:
gentlemen,
Is the swing arm still on the bike?
If not then put the bearings in the freezer over night and tomorrow heat the swing arm in the oven to 250°. They'll slide right in.
Or install the big one on the axle before you install it in the swing arm then tap the smaller one in and slide the axle through. Use a drift to whack it in till fully seated. Don't forget the washer on the end of the axle!
Edit: I think the last time I did this the swing arm was still attached so I used a heat gun on the swing arm bearing seats and hammered it in with grease on the outside of the bearings to help them slide in. Froze the bearings first.
VNB5 Vespa
VNB5 Vespa
everything is installed, i was riding and then noticed my front wheel came loose, the nut that holds the axle came undone so, i just removed the axle but damaged the smaller bearing and need to replace it. i will try the heat. i did freeze the bearing though on y first of many attempts t install
@davids_allstate avatar
'61 Allstate / Vespa VNA with a '69 veloce 150
It was pretty scary, we were riding in Downtown Mount Airy and Rick's steering went limp! We saw how loose the axle was we got him a truck ride home!
He's been trying many tricks to get it back in, Rick, tell Tami the oven is yours tonight.
Riding buddies!
Riding buddies!
@garncarz avatar
1964 Allstate Cruisaire, 2022 Husqvarna Vitpilen 401, 1972 Suzuki T500J
@garncarz avatar
Nothing I can say won't be deleted by the moderators. Wha? emoticon
I tried to give him a ride back to his house and as soon as I turned the throttle front wheel was in the air!
Good times!
We need a fun Rally/Ride out in this part of NC!
[ Time: 0.0107s ][ Queries: 4 (0.0035s) ][ live ][ 318 ][ ThingOne ]
