Hello there! New member here. 2016 GTS300 rider here from Durham, England U.K.
I'm going to add an additional USB power outlet. The outlet I'm considering buying has dual USB A and C ports has the following specs :-
Input voltage range: 9-32Vdc
Output voltage: 5.2Vdc +/- 0.2V
Max Output Power: 3.6A
Off load current (quiescent current): <2.5mA
Power conversion efficiency: 90%
Operating temperature: -25°C to +55°C
Connections Input: 6.3mm push-in flat blade connectors
Output: 1 x USB A Socket & 1 x USB C Socket
Is the stated input and output voltage suitable for a GTS330ie?
I'm awaiting delivery of a cable which connects / plug and play into the scoot's existing USB wiring loom such as sold by ScooterWest.
Many thanks...
