2020 GTS300 Supersport HPE. I keep getting bad roller or clutch rattle at low speeds when accelerating slowly. Only 6,000km on the clock, had Dealer 1st service at 1,697km & they "Stripped, checked, cleaned & reassembled belt drive & rollers". They couldn't find any issues. It seemed to be fine for a while, but came back slightly, then about 5,000km started to get very bad again. I did a service the other week & took the opportunity to clean & deglaze the clutch pads & bell with some 60grit sandpaper (didn't inspect rollers as I couldn't find part of my flywheel-holding tool
). It totally disappeared for about a week, but again has started to come back.
Is this a common issue? Is a bit of roller/clutch rattle just to be expected? Do I need to be more aggressive in deglazing? Surely the rollers aren't done already @6,000km?
