I've got a newly built P200 engine (I built it, first time I've done that from the ground up) that immediately showed signs of a leaking clutch-side main seal. Massive amounts of gasoline in the gear oil. I finally got the chance to take it fully apart. The seal (the brown metal one) seemed to be installed correctly, but the interior rubber/spring portion looked to be a *very* loose fit on the crank. It was admittedly cold in my garage (45 degrees f) but the inner lip of the seal made no contact with the crank (a Maz cut rotary-pad crank). I've attached a photo of the seal installed, you can see how much daylight there is between the seal inner and the bearing. I also have a blue corteco seal that is also loose on the crank.
Any ideas?
