And big thank you to Scooterpartsco Motovista for selling me the RMS Big Bore Kit and giving me some good advice.
I bought a LX 50 with constant stalling problems. After much research, i got an unrestricted CDI from Scooterpartsco, and the stalling was a thing of the past. I then got thinking that the LX 50 was not very good on hills, which led me to looking at Big Bore Kits. I decided on the cast iron 80cc RMS kit which Scooterpartsco has on discounted sale for about $100. That's about 1/3 of the Malossi kit (aluminum though).
Thanksgiving 2024, I decided to install the Big Bore Kit - in my apartment! Bit messy, but I put down cardboard and plastic. Removing the engine from the frame takes about 30mins. The cylinder change takes about 2 hours for a novice - spent a lot of time reviewing the instructions I had made from Scooterwest's video. I did make two dumb mistakes - which I caught when I rewatched Scooterwest's video after I had buttoned up the engine. Thankfully i had not installed the engine in the frame yet - wasn't going to do that until I had triple-checked my work.
First mistake was that I installed the black plastic lower cam-chain tensioner guide backwards. So I had to remove the engine head to fix that, which in the process I noticed that I had neglected to install the new Naraku camshaft which Scooterpartsco had sold me - yes I had even pressed a bearing on it, but somehow put the stock camshaft back in the engine. So that mistake on the tensioner guide actually helped me to get the correct camshaft installed.
While I had the engine off the frame, I changed the sparkplug, the drive belt to a Malossi, the roller weights to 5.5 grams, a new Malossi red air filter, and a RMS rear shock absorber.
Messing around with the drive belt is a bit tricky, and I stupidly removed the kickstarter c-clip in the process of taking off the variator cover - which led to a lengthy fight to get the kickstarter spring seated again. In the end, you need a interchangeable bit screwdriver (with no bit in it) to put on the spring and push it while someone else puts the moongear into place. For putting on a new drive belt, compress the rear drum spring then use visegrips to hold the belt in place on the rear drum so you have slack for putting the belt on the front drum.
I did have quite a bit of trouble getting the muffler on and off, in the end I did it while the engine was out of the frame. I am not looking forward to having to remove it to change the rear tire.
Putting the engine back in the frame is easy if you have a motorcycle jack. I cranked over the starter, and after about 20 seconds, the engine fired up - the carb was fuel starved from being upside down during disassembly ( I should have sucked on the vacuum hose to fill the carb before trying to start the engine).
I drove it around for about 5 miles at moderate speeds, it ran well, climbed hills with ease, etc - but it stalled at idle. I ended up setting the air/fuel mixture screw to 2.5 turns out and adjusting the idle screw, which solved the stalling. I am running a #77 main jet at the moment - per Scooterpartsco recommendation - and a stock #35 idle jet. I have spoken with some Piaggio workshops in Italy and they told me to use #80 or even #84-86. I was told to keep increasing the main jet until it bogs, then to reduce by two sizes.
One unexpected thing is that ScooterWest video says that the LX50 takes 850ml of oil. I drained the old oil, then measured 850ml of Motul 10W-40 Break-in oil, but was only able to get 650ml into the engine before the dipstick was indicating oil level was at max. In the owner's manual it says that while the total capacity is 850ml, if you are doing a oil change you will only be able to add 650ml since about 200ml remains in the crankcase.
Summary of upgrades:
RMS 80cc 4T 2V cylinder, piston, rings, wrist-pin, and gaskets
Naraku performance camshaft + SKF 6201 C3 bearing 12x32x10 mm
Malossi 727x18.5x30 kevlar drive belt
Malossi 5.5 gram rollers
#77 main jet for carb
NGK CR8EB sparkplug
Motul 10W-40 Break-in oil (will run for 600 miles)
Carb bowl allen bolts
Scooterpartsco also sells a complete RMS 80cc Big Bore Kit including the main jet, Malossi air filter, and Naraku camshaft.
Some very useful items to have:
Motorcycle jack
Valve feeler gauge
Carburetor screwdriver set
Digital torque gauge adapter
1/4 drive swivel joint
1.5x strength reading glasses
Variator tool for front sprocket
Clutch tool for variator rear drum
Visegrips
Assembly lube
Blue Loctite
Black marker
1/2 drive breaker bar
⚠️ Last edited by Landy89 on UTC; edited 10 times
