@garncarz avatar
1964 Allstate Cruisaire, 2022 Husqvarna Vitpilen 401, 1972 Suzuki T500J
@garncarz avatar
Gents:
I could use some help troubleshooting a problem with my '64 Cruiseaire. She starts well, usually on the first or second kick. When accelerating from a stop, especially on a slight incline, I need to increase the RPM's to 3000 to 4000 and slip the clutch in order to get the motorcycle rolling, otherwise it stalls. Otherwise, performance is as it should be.
I have ultrasonically cleaned the carburetor and all the jets are stock sizes and OEM. Idle is set to ~1000 rpm. Confirmed good fuel flow from petcock. Fuel filter is clean. I have set the ignition timing at 24 BTDC (static) and the points gap at 0.5 mm. Spark plug is an NGK B7HS gapped to 0.6 mm but are black in color. Pilot air screw is at 1 ΒΌ turns out. The cylinder has been honed and new rings have been installed. The muffler has been BBQed. Fresh Motul 10W30 Transoil in the crankcase. The air filter is stock and clean. HT wire and spark plug cap is new.
Any insights would be greatly appreciated. Cheers.
@veloce_vulture avatar
1957 NSU Prima III
1957 NSU Prima III
Idle seems high, kinda tough to set up correctly when it's this high. I'd use a Bosch copper plug for this bike. Nice write up tho.
W8AC
'74 50s x3 '87 PK125XL '92 PK50XLS Plurimatic - & - '58 AllState '68 Sprint '66(?) Super125 '72 DanMotor Super150 and '04 Bajaj LML hybrid
Your idle is same as most of mine and a normal NGK plug should be OK, but you might try retarding your timing. It seems to be out at the end of the recommended range on the chart I found at BeedSpeed to confirm, and there's also this:
Please Note: Older recommended Ignition timing setting where for 2 star fuel. Modern unleaded fuels tend to move the timing a little closer to TDC.
https://beedspeed.com/en-us/pages/vespa-standard-ignition-timing
W8AC
That's a low idle from where I'm from.
@chandlerman avatar
Lucky
255 Days Since Last Explosion
Lucky
@chandlerman avatar
Is this a new behavior, indicating something changed, or you just want to "fix" the issue?
Your stock bike simply doesn't generate enough power at less than 3-4K RPM's to get you moving on a hill, which means the only way to "fix" it would be to put a more powerful top end on it, which it sounds like is not the direction you want to go.
Retarding the timing will probably make the issue a little worse, if anything.
@garncarz avatar
@garncarz avatar
This is a new issue that I am working to resolve. I currently need to be at 1/2 throttle and slip the clutch to get rolling at all. Even on level ground. I almost think the clutch is binding?
@chandlerman avatar
Lucky
Lucky
@chandlerman avatar
Random-ish thought, but make sure your jets are all tight in the carb.
If the main stack has worked its way loose, it might have richened things up to where you're losing the lower end power.
@garncarz avatar
@garncarz avatar
Thanks, I'll give it a look.
@subetherbass avatar
Have you checked the GEARBOX OIL?
was it NOT USED for a long time?
- if not used, could br that CLUTCH PLATES are sticking together
@garncarz avatar
@garncarz avatar
I checked the jets. All nice and secure. Any yes, I too think it might be clutch related at this point. Will dig into it this week. Thanks.
[ Time: 0.0108s ][ Queries: 3 (0.0022s) ][ live ][ 318 ][ ThingOne ]
