Hello colleagues,
I am assembling my first vespa engine, I will tell you a little about how I intend to do it. The engine is a 73M px iris 200, 1987.
Malossi sport 210 cylinder with its Malossi cylinder head, It is the 2016 model, not the last one.
Engine casing with enlarged ports and enlarged rotary intake according to Malossi manual.
Polini crankshaft advanced with stroke 57.
Pinasco vrx 24 carburetor with its venturi. The diameter of the carburetor is 26. I currently have this carburetor on the stock engine, I ordered a 24 and it came in 26mm. I think those are the important things about the configuration.
The goal is a reliable touring engine... and the faster the better.
Now comes the main question and it is about the ideal squish.
On the one hand, Malossi recommends 0.8mm. On the other hand, I have read that closer to 1 mm is better. Malossi says 12.5-1 compression.
I have also read that when breaking in the engine, a higher squish, or lower compression, is advisable, and once the engine has been broken in, correct it and lower it to the recommended 0.8mm.
A larger squis than recommended, I have also read that it is not good since it takes more temperature...
I don't know how important it is, we're talking about a difference of 0.2mm.
I have the different joints for it, and I would like to close it and not touch it anymore if it is possible. Right now the squish is at 0.92-0.94mm. Not closed the head.
How do you see it? What do you recommend me?
Ah! I have two cdi options, fixed and variable vape. The fixed one at 18º, but what about the variable one? 23? 22?
Is the variable worth it?
Thank you very much in advance. Kind regards.
