GTS 250 ie
GTS 250 ie
Without the engine running the indicators function correctly . With the engine running, after about 20s the indicators stop working. Switch the engine off. They start working again.
I have checked and the voltage regulator seems to function correctly - 13.8v with engine running.
Any suggestions?
check the main ground for corrosion and good contact.
GTS 250 ie
GTS 250 ie
Thank you will do
[ Time: 0.0072s ][ Queries: 3 (0.0015s) ][ live ][ 319 ][ ThingOne ]
