VMC 187 crono top end
Sip 60mm toothed crank
VMC 10molle toothed clutch
68/21 stock Stella gearing
Mrp reed intake
SIP reed block
Vape variable ignition
-If anyone wants to chime in on what carb to use, I was planning on a phbh30. -The exhaust I was thinking was the racing SIP performance 2.0 right hand expansion chamber exhaust, mostly due to the large frame Indonesian racers all using right hand expansion exhausts, so clearance must not be an issue? Assuming you'd hit selector box before exhaust, but Open to suggestions.
-used stock Stella gearing to have as much acceleration, top speed not too important for the track, open to gearing suggestions though.
To make things worse for myself, this is my first full motor build, so doing everything with no real blue print will be…interesting. Hope yall enjoy, appreciate the help along the way.
⚠️ Last edited by JohnDon on UTC; edited 6 times
