PHBH 30 Slide is catching and won't slide super smooth on the needle- somehow needle is pretty beat up. There's a bunch of sizes- how do I tell which size I have? Thickness? Length?
I only know PWK's, but the needle size/attributes are stamped up near the top of the needle on PWK needles.
If there's nothing, then assume it's stock for your carb, google up an answer, and order another. Jetsrus.com is my go-to for side draft needs, jets, etc.
Found it! About 1/4 of the way down the needle- below the notches. Cheers buddy.
