Does anyone know if a 2009 Sportcity Cube 250ie Air Box will fit\or is a crossover part that will fit a 2009 BV 250. I think the motors are the same but I am not sure if the CVT cases are the same or if the case bolt locations are the same.
My theory is if the case bolt are the same, then the BV 250 will fit but I may have some fabrication for connecting the intake.
I own the 09 SC Cube 250 and there is an air box from the 09 BV 250 that I can buy but I am not sure if i will fit.
