A brief recap of the situation.
Several weeks ago, I hopped on my '20 GTS300 HPE in anticipation of an early December ride fifty miles through the Black Hills 'up' to Deadwood for my coffee and muffin (orange/cranberry).
While riding to the gas station two and a half miles up the road so that I could spill overflow gasoline all over the general fuel tank neck area, the engine started to, as they say, 'bog' on applying full throttle and refused to run at anything over about 40-45 mph.
The bike has been doing this for some time, but never as severely as it was now.
Disappointed, I hobbled back home and parked the GTS until yesterday.
I was hoping that the problem had something to do with the ASR system, which would have been the least problematic of all the things it could have been. In an earlier thread I had posted here concerning my...concern, the ASR system was mentioned by several as a possible cause, so I found a video on resetting the ASR (I can't find my owner's manual, of course).
So yesterday, in our glorious late December 54 degree weather (F), I tried to get the ASR right with the world, but couldn't get the flashing 'ASR' words on the dash(?) to go solid from the blinking on and off part.
I did, however, get the ASR indicator to go off entirely, and the GTS ran perfectly for the short five mile ride over the same route that it had had problems with several weeks ago. It ran at full throttle up a slight grade just fine, and would accelerate to, and run at, an indicated 72 mph.
Apparently, the ASR system defaults back to 'on' every time the GTS is started anew, but I will turn it off again today and try to ride it for a longer distance and see if my possible good luck with it will continue.
Believe me, I DO hope that the fix is truly as simple as this may be, because I have no desire to haul this bike 400 miles to have a real Vespa mechanic diagnose it's problem. If I did have to haul it that far (in the spring) and at that expense, my temptation to leave it there might get the better of me.
I am also pleased to report that I got my old Honda CB900C running yesterday as well, seems all it needed was a new battery.....and (blush), gasoline.
I'll report back my findings this afternoon.
