@petrus avatar
P200E DN 1982
@petrus avatar
P200E DN 1982
I was looking for a vented gearbox oil level plug (with tube).
Was very kindly provided with a link to one which allows for a bit more oil and be nice for the clutch.
The is that I now cannot re-find the link nor the product Facepalm emoticon
@ginch avatar
@ginch avatar
https://avotecnica.com/it/impianti-frenanti/3924-sfiato-olio-vmc-per-carter-vespa-large-e-small-frame.html
Works really well. I did have an extended tube on the clutch cover originally but from time to time it would pump oil out on to the floor through 300mm of tube... not sure how that works tbh!
It's probably the same breather you can get from Aliexpress for dirt bike tank venting but having the M7 thread at the bottom saves a lot of mucking around.
@petrus avatar
P200E DN 1982
@petrus avatar
P200E DN 1982
THANKS again!!
The ´blow out´ could happen if the end of the tube is lower than the plug and the hot oil level goes over the highest point of the tube. Next it is simply a gravity fed siphon.
Weird scenario though.
@qascooter avatar
@qascooter avatar
Now if my gogolefu was only good enough to find that in the states!
@roland87 avatar
@roland87 avatar
Yeah. Biggest problem that there is no fittings with M7 on the Aliexpress. I searched a lot.
Petrus SIP have nice one Salem Speed.
@petrus avatar
P200E DN 1982
@petrus avatar
P200E DN 1982
Very nice indeed Roland. Want one. Have put it in the shopping cart to combine with later whatever.
@che-storto avatar
@che-storto avatar
I always find it next to the blinker fluid and muffler oil, on the top back shelf at the Vespa store....
@ray8 avatar
@ray8 avatar
I posted a breather mod on page 17 of the Random tricks thread.
Only cost is the 10mm fuel hose and a zip tie.
Test the main seal by finger Clap emoticon
@petrus avatar
P200E DN 1982
@petrus avatar
P200E DN 1982
thanks Ray.
Will do asap.
Not routing the plastic pipe down though. A bit of foam should suffice.
I will be a lot happier with some 100 cc more oil in there.
@bajarob avatar
@bajarob avatar
I just cut the top off a stock breather and turned it down in the lathe to fit the tubing I had. Didn't cost me anything since I already had it. 😉
@roland87 avatar
@roland87 avatar
Original breather was absolutely ok for my engine with 350-370 ml of oil in it.
@roland87 avatar
@roland87 avatar
Here is the baby-breather from Aliexpres
On my mate's PK cases was somehow was broken breather thread. I decided to put M6 helicoil and this Ali-breather. But it seems that better was to cut M8 thread and order bigger breather.
@mod_eric_the_skin avatar
'59 VBA 166, '05 Stella 177, '80 P125X, '79 P207, '80 Chetak
I used this old style fuel tap I found in a bin. Took off the nut, snipped the filter off and used a little rtv to hold it in the hole.
@petrus avatar
P200E DN 1982
@petrus avatar
P200E DN 1982
I want the vent tube up and only up, so the box/housing can hold more oil without risk of syphoning.
@ray8 avatar
@ray8 avatar
By adding more oil, more oil is flung at the breather by the primary gear.
No risk of siphoning, since the oil level is nowhere near there.
@petrus avatar
P200E DN 1982
@petrus avatar
P200E DN 1982
Good to know, thanks. Then I want it vertical so anything flung at it will drip down, báck into the case and not anywhere else
My nigh traumatic history with crankcase/gearbox/diff breathers spans júst short of half a century Facepalm emoticon
Would fill a whole, and I admit slightly worrying , chapter in an autobiography ROFL emoticon
@roland87 avatar
@roland87 avatar
I'm interest in how EGIG's breather works? It have no tube but a ball inside. And works with 500(!) ml of oil in smallframe engine...
I have one on the shelf but still not installed.
Original breather spit lot of oil after 220 km of highway ride.
@petrus avatar
P200E DN 1982
@petrus avatar
P200E DN 1982
Ah the ball type. It is gravity operated. Some even have a light spring.
Almost overkill for gear box temp. expansion ´pressure´ as the weight of the ball keeps the opening under its seat closed most of the time.
The OEM one is an open hole with a hat against rain/dirt so adding a ball with a good fitting seat is way better.
The EGIG valve has a close fitting ball with small relief passage only. It should indeed do a good job for both eventing and keeping oil in.
The design fitted with a light spring is a lót better still as this keep it staying put over bumpy surfaces. This makes that the valve is mostly closed and is only pushed open by pressure inside. It will keep oil in side.
The free hopping ball design was in the past used on some motorbikes as cheap pcv valve and boy was that an air filter oil fest
Yes the EGIG valve is all I would need but Ray8´s for free mod allows easy filling through the vent tube.
Today got a piece of clear plastic 10mm (inside diameter) pipe from the farm. Also for free as it was a left over cut off.
@orwell84 avatar
@orwell84 avatar
I think I've been having senior moments since my mid 20's; losing parts and tools, thinking I've ordered a part when I haven't and hunting for it. Buying the same part multiple times.
@petrus avatar
P200E DN 1982
@petrus avatar
P200E DN 1982
So well practiced, they don´t surprise nor trip you up as Facepalm emoticon anymore
Tip; have the name of your partner ´tattooed´ in Henna on your pulse ROFL emoticon
[ Time: 0.0147s ][ Queries: 4 (0.0059s) ][ live ][ 343 ][ ThingOne ]
