Greetings to all.
I recently put some 12.5 gr Dr. Pulley rollers on my 2011 Vespa GTS with the precaution of putting the 1.3 mm variator separation washer, I already had the Malossi clutch installed. In the test with the stand on, the clutch began to slip, releasing debris from the clutch shoes. Can anyone give me some advice. Thank you
