Ray8 wrote:
The headset is damaged beyond repair.
Looks like it ran into a telephone pole. Bent fork too? Idk
In all cases you have to ask yourself, "why did this bike end up being stored?" It's always something.
I'm pretty much in agreement with all of the comments above, and I've rescued a few bikes that ruff or even ruffer. As far as the price, it is on the low end these days and is reasonable depending on location and:
1 Does it have a clean title
2 How does the bottom of the floor look, any serious rust
3 Does the engine turn over smoothly, are the rest of the missing engine parts included
4 Are other parts included - engine door, gas tank, speedo, headlite trim etc
And 5 Has it had a front end collision???
#5 I think maybe not. The front wheel is well centered in the mudguard, and it seems the only problem w/ headset might be just a busted front brake lever perch(I had similar fixed w/ easy weld repair) but it's hard to tell without seeing more. How about a straight on 90° shot of front wheel from the right side so we can see the bottom of the fork, please?
