Rev. B.
Completely cut out center divider, grid both sides, and half of the external snorkle. Bellmouthed the outer edge of external snorkle. Fabbed a bridge for air filter support to replace divider.
It works. Primary concern, injection is able to adapt. Currently running a Malossi O2 emulator but confidant it would be fine without. Also have a slightly larger injector to swap in to try. Suspect it will be very lean open loop.
Sound: better than expected. Not too loud, throaty with a bit of honk when snapped wide open.
Performance: I think it's faster, hard to tell as roads are wet and I can feel it fishtailing as the tire spins. Will need a dry day for proper evaluation. Don't normally ride in the rain but couldn't wait to try it.
How it was done: Xacto knife and Dremel. Cut the grid into small pieces, scored at the base, then bent back and forth with pliers to break off. Cleaned up with Dremel grinding stone. Very time intensive, estimate I have 20 hours in it at least.
No pics, was in a hurry. Will get some pics when I take it back off.
Pics of rev. A, slight mod to divider, bellmouthed snorkle, and grid cut out of outer half.
