LX 150 2013 & GTS 300 2015
The button to change the clock and reset the tripdometer stopped working.
It used to work intermittently when I press it very hard, but now not at all.
How hard a fix is this? My clock is 52 minutes off and I would like to get it accurate again.
Thanks!
@gtdespatchcourier avatar
GTS 300ie
GTS 300ie
Spray contact cleaner into the back of the button to clean the rusty contacts.
@bluecloud avatar
2018 GTS Super
@bluecloud avatar
2018 GTS Super
I think you can actually pry the switch open probably with a small screwdriver for a deep clean. Worst case a new switch.
does anyone know the part number or where I can buy a new switch?
@bluecloud avatar
2018 GTS Super
@bluecloud avatar
2018 GTS Super
Vespa p/n 641859 for the round mode button.
Should be 5-6$ from your local dealer or any of the online vendors: Scooterwest, Scooterpartsco, or AF1.
thanks, does anyone have a guide for how to open the handle bar area correctly so I may replace it?
@bluecloud avatar
2018 GTS Super
@bluecloud avatar
2018 GTS Super
That's the hard part. Don't force it, you will break tabs.
https://manuals.wotmeworry.org.uk/Vespa/GTS300-2015-ABS/GTS300-2015-ABS.pdf
[ Time: 0.0093s ][ Queries: 3 (0.0034s) ][ live ][ 343 ][ ThingOne ]
