@danie avatar
@danie avatar
On a PX200E with a faulty fuel gauge: how do you determine whether the problem is the fuel gauge (in the tank), or in the speedometer?
@ginch avatar
@ginch avatar
If you have a friend with a P, you could try running extended wires to his sender and see if your gauge responds. That would be an easy starting point.
@safis avatar
@safis avatar
Since it's an AC system, while the engine is running, undo the plug from the tank sensor and bridge consecutively black to white/black and black to white/green. If the wiring and speedo is OK, one combo will max the fuel level and the other will light up the reserve...
@danie avatar
@danie avatar
Thanks Safis, appreciated
[ Time: 0.0117s ][ Queries: 3 (0.0051s) ][ live ][ 339 ][ ThingOne ]
