LX50 2007
LX50 2007
I've been searching and have been unable to find a rebuild kit for my 2007 LX50 4t carburetor. The gasket on the float bowl is leaking and i'd rather not replace the whole carb since it runs well once it gets going. I've even had some struggles finding the right P/N for the carb but this one seems to say its compatible. Looking up the part numbers listed shows that it may actually be for the 2t models not the 4t. Any help would be appreciated, thanks in advance.
you can buy a replacement carb from aliexpress. It will be of low quality, but you can disassemble it and use the gaskets from it to rebuild your stock carb.
Amazon sells rebuild kits for CVK18
⚠️ Last edited by Landy89 on UTC; edited 2 times
@abner_bjorn avatar
@abner_bjorn avatar
How hard did you look?
[ Time: 0.0122s ][ Queries: 4 (0.0042s) ][ live ][ 339 ][ ThingOne ]
