In the process of starting my VBB engine for the first time. It has a 177 kit and a new 20/20 carb.
It starts and runs and sounds great, but ONLY if the slide in the carb is nearly halfway open. If I let the slide close any further, the engine shuts down.
I can see fuel coming out of the nozzle when the slide is half open, but no fuel seems to be coming out when the slide is open any less than that.
Obviously, under the circumstances, there is no way to set idle with the idle screw. The slide has to be much more open than the max range of the idle screw. I can only start and run the engine if I'm pulling on the accelerator. If I let the throttle cable go, the engine dies, no matter where the idle screw is set.
Main jet is 114 and the atomizer is a B4.
Anybody have any guesses about what's going on?? The main symptom is that no gas is being pulled out of the carb throat nozzle unless the slide is way open.
Here's a pic of how far the slide has to be open for the engine to run at all (a little hard to read; sorry). Thanks for any and all wisdom!!
