I order a new crankshaft part number 8411965002 CAT 2 (as per the catalogue) and comparing it with the old one that snapped it actually doesnt have a shoulder so the timing chain sprocket/pinion cannot go all the way and sit flush.
I measured the internal diameter of the chain sprocket/pinion and its 17mm and searching online for the part number I am unable to tell what the diameter is of a new one.
The shoulder on the new cranshaft is about 19.5mm so I guess I need chain sprocket/pinion with that diameter.
Part number 82782R
Another issue is that on the other side the old one had a woodruff key slot but the new one doesnt...
Please help or if you have data/catalogues let me know what is correct.
Help!
