I have a question about MP3s, and I don't want to take everything apart to be able to do the tests.
When switching from low to high beam, does the original harness switch with the positive or does it do so with the ground? In other words, does the original harness of the bike use the ground as the constant (always present in the bulb) and then feed the high or low with +12v, or is the positive the constant and then feeds the high or low with ground?
Thanks for the help
