@eindhovenaar avatar
2016 Piaggio MP3 Yourban LT 300ie
Hi all,
As stated in the title the red 'Run' button on the right seems to be malfunctioning. I know for sure that it used to work as intended just a couple of weeks ago.
Now when the engine is running and i switch to off, the engine keeps running but the light in the dash does turn on, indicating that it somehow is recognizing the switch position.
Anyone have experience with this behavior? See the video below:
https://youtube.com/shorts/gvNZGuKGieQ?si=lCz_v4Z4oNLjr7pf
2015 MP3 500 ie Business
Best to use the ignition switch to stop the engine.
The kill switch is not meant to be used for daily use, and rather for emergency instances.
but if you don't use it how be it you know if its going to work or not?
The only time I use the kill switch is after a oil service, when I double check the oil level after the oil pump has built up pressure and the oil pressure light goes out.
For all other occasions I use the key
[ Time: 0.0080s ][ Queries: 3 (0.0025s) ][ live ][ 339 ][ ThingOne ]
