@ushi avatar
Vespa PX
@ushi avatar
Vespa PX
Hello, this is my first post on the forum, although I've been watching what's going on here for a few years.
I'm currently rebuilding a Vespa PX 200 (without a battery and starter). I'm replacing all the electrics and I have a problem.
I bought a new installation and I already have an SIP speedometer.
I would like to buy a VAPE ignition - and here the question arises whether the AC version will work properly with the SIP speedor? Or do I have to choose the DC version?
GL150
GL150
The AC Vape and SIP speedo combination is working fine for me, but I have read posts saying DC with a battery is needed so it may not be guaranteed to work.
@safis avatar
@safis avatar
Yes, it works just fine with AC. I assume you already have the speedo working, just install the VAPE stator. You can keep the stock regulator. In the speedo settings change the rpm pulse from 3 (Ducati ignition) to 6…
@roland87 avatar
@roland87 avatar
On my mk.I P SIP speedo works with standard AC PX ignition. Sometimes it turn OFF-ON on the very low idle revs.
@ushi avatar
Vespa PX
@ushi avatar
Vespa PX
I have same issue now on standard PX ignition. I am about to install vape to avoid these problems and in the near future I want to install VMC Ranger
@ushi avatar
Vespa PX
@ushi avatar
Vespa PX
Another question: to use this headlight I need battery and DC installation?
@hec_in_omaha avatar
1980 P125X US Spec
1980 P125X US Spec
I am watching this thread! I am also contemplating installing a Vape DC Electronic ignition in my P125X that has points and a single yellow wire stator and 12V Battery. In addition I have a SIP Rev Counter 2.0 Speedo installed. Can it be done and still have all the functionality of the SIP Rev Counter 2.0 Speedo?
Popcorn emoticon Popcorn emoticon
Hec
@ray8 avatar
@ray8 avatar
For sure you'll need DC feeding that badboy.
If you decide to go Vape DC, I highly recommend adding a battery.
@ushi avatar
Vespa PX
@ushi avatar
Vespa PX
Thanks for reply. I have bought new electrics (Italian version, super simple) and I don't feel it will be good for DC. So I think I have to give up led headlight.
@safis avatar
@safis avatar
Friends run Aliexpress LED headlights on AC and they work fine. They flicker a bit and some burn out eventually…
@ushi avatar
Vespa PX
@ushi avatar
Vespa PX
Maybe You can post a link of AliExpress offer?
@safis avatar
@safis avatar
Any 5.75" Led headlight will fit a PX. Just pick the one you like…
@ushi avatar
Vespa PX
@ushi avatar
Vespa PX
SaFiS wrote:
Any 5.75" Led headlight will fit a PX…
Thanks!
I run an LED on my AC electric system and haven't had any problems. It does flicker a little at stops but I don't mind it. I rarely ride at night so I barely notice it.
@ushi avatar
Vespa PX
@ushi avatar
Vespa PX
Do You have standard ignition?
@ginch avatar
@ginch avatar
I have a Vape and SIP speedo. Still needs a battery to avoid the speedo shutting down at low idle.
@ushi avatar
Vespa PX
@ushi avatar
Vespa PX
This is not the message I would like to read :/
@ginch avatar
@ginch avatar
No! I prefer the SIP Vape advertising that says "90 watts at idle" or some such nonsense.
Sadly it's just not true and it's better to know in advance, and not wonder what you have done wrong.
@ushi avatar
Vespa PX
@ushi avatar
Vespa PX
I think you effectively cured me of buying a vape. Especially since a light wheel probably won't be a good idea for a 200 engine
@safis avatar
@safis avatar
Both smallframes that I restored (friend's ivory V50s and orange Special) run fine on idle and speedos stay ON. One has a Vape ignition, the other a PK 12V stock Ducati, both with the AC Vape regulator…
@ushi avatar
Vespa PX
@ushi avatar
Vespa PX
You have a sip speedo? Normal or led bulbs?
@safis avatar
@safis avatar
SIP speedos, normal lights…
1980 P125X US Spec
1980 P125X US Spec
Ginch,
I am thinking of getting a Vape DC Electronic Ignition. I have a SIP Rev Counter 2.0 Spedo. I would be installing it in my 1980 P125X project. The light bulbs are all stock to include the headlight, it has a 12v battery. Will I get full functionality of the SIP Speedo to include the tachometer?
Hec
@ginch avatar
@ginch avatar
I don't know what you're doing differently to make them do that. Mine has shut down at low idle since it was new.
Hec In Omaha wrote:
Ginch,
Hec
I've never connected my tacho so can't help there sorry Hec. If you have a battery in the system there should be no obstacle to proper functioning.
@safis avatar
@safis avatar
I don't know either ROFL emoticon ROFL emoticon ROFL emoticon
Both have a BGM 12V conversion loom and the Vape AC regulator...
@ginch avatar
@ginch avatar
My speedo is the 2nd version, must be at least 7(?) years old now. I wonder if newer ones have a built-in capacitor to get them through the low voltage states?
[ Time: 0.0103s ][ Queries: 3 (0.0030s) ][ live ][ 341 ][ ThingOne ]
