S150
S150
My 2014 fly has a silent block support like this one. It rotates up and down and the two holes have nothing attached to them. Is that normal? Or has something fallen out somewhere? The only attachment is through the silent block and the spring. Thank
You
I'm not sure what MY Fly the parts list I have refers to, but the silent block looks very different:
@bluecloud avatar
2018 GTS Super
@bluecloud avatar
2018 GTS Super
2014 Fly 150: https://www.af1racing.com/ProdImages/st3/NSEN000US1.pdf
See page 185, supposed to be bolted to frame.
S150
S150
Thanks. It looks like 15 and 16 go through a hole on the bracket but that's it
That's more like it! Thanks.
@bluecloud avatar
2018 GTS Super
@bluecloud avatar
2018 GTS Super
Should be corresponding holes on the frame as well. GTS with similar engine suspension silent block bolts to frame.
I can only imagine what the ride must be like with only that tiny spring, silent block bolted to frame is what makes it work.
S150
S150
This is what I'm dealing with when I bolted to the frame. It has no movement to go on and off the Center stand
@bluecloud avatar
2018 GTS Super
@bluecloud avatar
2018 GTS Super
What do you mean, need a bit more detail. Engine swingarm shouldn't affect center stand function.
time to take it to a professional and let them fix it
S150
S150
I got it figured how it's all good now. Thank you
Give us a clue - what was it? Someone else in the future might need this info!
S150
S150
The bracket for the silent block was out of alignment so I couldn't get it to lineup with the holes on the frame I disassemble the silent block and put everything back together and then it lined up fine bolted it up and now there's no issues
[ Time: 0.0111s ][ Queries: 4 (0.0042s) ][ live ][ 343 ][ ThingOne ]
