Hello all.
I have a 1980 100 smallie I haven't used for years and I'm in the process of reconditioning it.
I used to have a strange issue:
I remember that when I used to ride it, the carb would always rotate slowly slowly with every ride. I didn't matter how much I would tighten it.
For example, when I would attach the carb on the manifold, the filter and the plastic tray would be under the carb. But then slowly slowly the whole thing would rotate like 45 degrees.
Sometimes also when I would go over speed bumps the metal filter would hit the frame making a banging sound under my seat. The noise would happen only when riding alone and when the rear shock would decompress. I'm around 75kg btw if you are wondering.
I took out the carb to clean it the other day and noticed that 1 of the 4 pieces on the mouth of the carb has broke off. I'm guessing either I overtightened it, or it was one of the speed bumps (we have loads where I live) (see attachment)
Anyway, now I'm in the process of ordering parts.
Do you think I need a rear shock?
Should I get one including a spring too?
Could It be something else?
Thanks ever so much and apologies for my english.
