My little finger wraps around the end weight, the others are on the grip.
FYI I'm 175cm slim build.
Posts: 8296 Location: Batmania aka Melbourne, Aus |
Does anyone else have their hands partially on the bar end weights?
My little finger wraps around the end weight, the others are on the grip. FYI I'm 175cm slim build.
GTS300 Super 2023 Beige
Posts: 3490 Location: Sydney, Australia |
Never done that. I just rest my loose hands on the grips, only gripping them when maneuvering. Approaching any situation, I have my fingers touching the levers.
Will have to start a separate topic about foot position.
Positive
Mike Holland wrote: Approaching any situation, I have my fingers touching the levers.
Positive
Posts: 1183 Location: Oxfordshire, UK |
SteelBytes wrote: Does anyone else have their hands partially on the bar end weights? My little finger wraps around the end weight, the others are on the grip. FYI I'm 175cm slim build. |
I've caught myself with the pinkies on the bar end weights on occasion. My current bike and current Primavera both came without the weights. While out on a long ride, I noticed my pinkie dangling over the end reaching for my O-ring for throttle lock. No longer use the O-ring, but find myself still putting the pinkie out on the weight sometimes on longer rides.
Coddy wrote: No, to what advantage do you achieve. Better control? |
I can recall riding through the Karoo semi-desert on my way to Cape Town sitting on the back of the GS150 dual seat, with a sandwich in one hand and a coke in the other. Who needs grips?
This was in 1961.
Positive
2023 and 2024 Vespa GTS300 SuperTech
Posts: 151 Location: Harrisburg, PA |
When they installed the Top case on my Vespa GTS300 Supertech they put on heavier bar end weights I removed them and put back on the factory installed ones. I didn't like the look and feel of the heavier ones does it really make a difference with the top case using heavier bar weights?
Jeffsvisor wrote: ... does it really make a difference with the top case using heavier bar weights? |
Mike Holland wrote: Probably depends on the weight you have inside the topbox. A heavy load there can definitely make the scooter unstable. |
SteelBytes wrote: Does anyone else have their hands partially on the bar end weights? My little finger wraps around the end weight, the others are on the grip. FYI I'm 175cm slim build. Funny thing is that my right hand tends to be partially on the bar end weights, while my left hand is always on the most right position of the grip on the handle bar. Deliberately shifting my right hand to the most left position on the grip only worked temporarily. It did not take long before I noticed after a few roundbouts and curves the right hand was again at its original position. |
Posts: 323 Location: Thornhill ON Canada |
When I replaced the OEM grips, I swear some of the buzzines in the bars was gone and the additional room was welcomed.
Whatever floats your boat.....
