Hi everyone,
First post, but been having a recurring issue that my bike doesn't want to start in the cold (I live in Canada) and been having issues finding a good resource to diagnose this.
When the weather is warm it always starts right up, and will start right up if it's still warm from the last ride, but as soon as the temperate dips below 10°C or so the electric starter isn't enough to get it going; but with several dozens of kicks it may start.
This was a problem in the fall before going away for winter indoor storage on a battery tender. Picked it up this week, and the guy running the storage got it started (with many kicks he said, it's a somewhat heated garage) before I brought it home. Ran great for the 5-10km getting home, but the next day I can't get it running.
Curious what diagnostics I should consider when it seems so temperature dependant; I'm willing to take it for service if needed; but I'm interested to learn more of the maintenance myself where I can.
A few more notes:
- If you message "with a few pumps of the throttle/cold start procedure mine starts right up in the cold" you'll hurt my feelings out of jealousy (this is far too often the advice I find lol)
- I kicked it far too many times today and noticed the kick wasn't as smooth by the end; is this something I should be worried about?
- I noticed the 'choke warmer' doesn't seem to be warm to the touch after leaving the key on for a few minutes, could this mechanism be bad (based on the issues it feels like it could make sense?)
Next step in my mind will be to pickup a can of starting fluid, but from what I've seen this shouldn't be required so I'd rather try to run through other 'tricks' or diagnostics first so that I can reliably get it going on cold mornings.
Any insight is appreciated, I'll do my best to keep an eye out and test what I can tomorrow.
