Vespa GTS 125 4T E4 ABS 2019 (EMEA)
Hi everyone,
I'm reaching out for some advice and support from fellow Vespa owners.
I own a Vespa GTS 125 4T E4 ABS 2019 (EMEA model) and recently encountered a serious problem: the ABS system has completely failed without any abnormal use or accident. The scooter has relatively low mileage, has been well maintained, and has only been used under normal conditions.
I went to an official Vespa dealer, and they quoted me €1,500 for the repair (€907.50 for the ABS hydraulic unit plus around €150 for labor). Honestly, this feels excessive, especially considering how crucial ABS is for safety and how early this fault appeared.
I'm writing here to ask for two things:
- Has anyone here replaced the ABS system on a GTS 125 themselves or found a more affordable solution, like using second-hand parts or alternative workshops?
- What would you do in terms of escalating this complaint? I've already filed a formal complaint with the dealer but am considering taking it to consumer protection bodies like national consumer arbitration centers, ASAE (Portuguese economic authority), or even Piaggio directly. I'd love to hear if anyone has gone down this road before and what worked.
Any tips on alternative fixes, compatible parts, or how to pressure the dealership/Vespa for a goodwill repair would be hugely appreciated!
Thanks in advance for any advice or experience you can share!
Cheers!
Vespa GTS 300
Vespa GTS 300
Welcome to MV and congratulations on your first post.
The ABS control unit for your model should have the SKU 1C007227 (old number 1C002747). The price is just under 1000€, depending on where you look (and what VAT is added). The installation time is given by Piaggio as 120 minutes (don't know your local labor costs per Hour).
How do you get from 900€ material + 150€ labor to 1500€?
Important: the ABS control unit must be taught to the vehicle by the dealer; this requires the PADS dealer system, which only authorized dealers have access to. Therefore, I assume that there is at least the risk that used parts cannot be adapted to another vehicle or that you cannot find a dealer who wants to do this.
I don't see any way to escalate this. What are authorities supposed to do with a technical component that breaks after 5-6 years? In Europe, Piaggio offers a manufacturer's warranty of 2 years, which has long since expired in your case. The words "goodwill" and "Piaggio" in the same sentence is an unimaginable combination, at least in Germany (it may be different in other regions). I don't see an option here.
Thanks GermanGTSDriver for the warm welcome and for the detailed information regarding the ABS unit and installation process.
You're correct about the numbers – the quotation I received from my local Vespa dealer in Portugal was indeed €907.50 for the ABS unit, around €152 for labor, but with VAT and additional "administrative" fees, they pushed the total to nearly €1,500. It felt excessive compared to similar cases I've now read about elsewhere.
I fully understand that the warranty has expired, but I am also aware that in Portugal, as in many EU countries, consumer law allows for complaints on hidden (latent) defects even beyond the 2-year warranty, especially when the defect compromises safety and occurs after very limited use. My Vespa has only 1,600 km, which is why I consider this premature failure as more than just "normal wear and tear."
I appreciate your point about the challenges of reprogramming a used ABS unit and the dependency on the dealer's PADS system – that was one of my concerns too when exploring less expensive solutions.
Thank you again for your insight – it helps me better understand the technical and procedural limitations!
Vespa GTS 300
Vespa GTS 300
The mileage is only one component that has an influence on the durability of products. Time and environmental conditions (temperature, humidity, salty air, etc.) are others.
In my opinion, there are no frequent problems with the ABS units, especially as these are also used in the GTS 300 / GTV 300 of various model years and possibly also in various Piaggio models.
Another indication: The SKU is an ordered item from the major mail order companies, i.e. there is no stock available. This indicates low demand. But you can search here in the forum to see how often / how rarely this topic comes up here.
I'm sorry, but you'll have to file that under "shit happens" and dig into your own pocket...
The approximately €1000 for the control unit includes German VAT (19%) / i.e. around €800 net.
What are the "administrative fees" in addition to the labor costs?
Joined: UTC Posts: 8307 Location: Batmania aka Melbourne, Aus
GermanGTSDriver wrote: Important: the ABS control unit must be taught to the vehicle by the dealer; this requires the PADS dealer system, which only authorized dealers have access to. Therefore, I assume that there is at least the risk that used parts cannot be adapted to another vehicle or that you cannot find a dealer who wants to do this.
this guy installed a 2nd hand abs unit himself without needing to use PADS
Both brake levers stuck while riding on my 2018GTS300Super (Post 2637111)
also my expensive OBDstar can config/setup a new ABS unit on the GTS (it has lots of vespa specific commands for both the ecu and abs and supertech tft).
