Vespa et2
Vespa et2
Hello everyone
After sitting outside for 7 years without used in trying to restore my Vespa
So far I have replaced the cdi unit which gave me a spark
Replaced the fuel line and fuel tap which was blocked
And now I have encountered yet another problem as when I try to crank it then after like 10 attempts it starts but only for like 3 seconds before slowly turning off this has happened Like 5 times now and even when adding throttle it still just slowly turns off and can't idle
Could it be a clogged up carburator or low compression?
Thanks to everyone,Oliver
@kevin_harrell avatar
2018 SYM Wolf 150
2018 SYM Wolf 150
Try replacing the spark plug. An old plug that tests good can still be enough off to cause problems. It is a cheep fix and can be all the engine needs to run right.
OK, I see in your other post you already replaced it.
Carb needs to be cleaned very well. It will be full of varnish.
[ Time: 0.0084s ][ Queries: 3 (0.0023s) ][ live ][ 343 ][ ThingOne ]
