Hi All,
Would love some wisdom from the forum.
I have a GTS300 HPE 2022 ABS.
I had the dreaded fuel pump issue and replaced the original with a kemso 13001.
Important to say, pump was working when cold (hot start was the issue) and the vespa was functioning well without any issue.
It required some fiddling, drop the engine, fuel tank etc... and pump went in ok.
When trying to start the engine, it cranks but won't start.
I'd love to hear your thoughts of what to check.
What I've tried so far:
1. Checking fuses + relay + pump is priming ok
2. Disconnecting fuel line, fuel is coming out when pump is making priming noise
3. Spark plug has a spark (checked via the cable to the body, did not take out the spark plug)
Any ideas would be appreciated
