Mp3 250
Mp3 250
I have a Piaggio MP3 250 and when it's warm and I turn it off, when I try to start it again, it starts but then stalls shortly after. When it cools down, it starts normally. Does anyone have any idea what might be causing this? Thank you."
@xristos avatar
Aprilia scarabeo 300 aprilia sl1000
@xristos avatar
Fuel pump.
Mp3 250
Mp3 250
The fuel pump is checked. It's OK they said. Thanks for the answer.
MP3 500 HPE 2019
MP3 500 HPE 2019
Check your VIN number for the dodgy fuel pump recall
when were the valves last checked / adjsuted?
@germangtsdriver avatar
Vespa GTS 300
Vespa GTS 300
At least for Europe, the Piaggio recall form does not list all recalls!
https://www.vespa.com/en_EN/recall-campaign/
Only the dealer or Piaggio itself can provide precise information.
Mp3 250
Mp3 250
The problem starts in the summer. I think something is getting hot. When it's cold the engine works as nothing happened.
Vespa GTS 300
Vespa GTS 300
The known thermal problems with the fuel pump can be easily diagnosed: If the fuel pump does not whir when the ignition is switched on when hot, but does so again when the engine is first started or after it has cooled down, then 99.9% of the time it is the fuel pump...
In other words: the engine can only start if the fuel pump hums briefly when the ignition is switched on and a corresponding fuel pressure has been built up.
If the fuel pump hums and starting is still not possible, the problem is somewhere else.
Did 'they' take it for a test ride to get it good and hot, then try to restart? They may have just checked the recall database, and noted that the pump pressurised just fine when cold.
Next time it's warm and you stop, listen for the fuel pump 'whirr' for two seconds when you first switch on and before you try to start.
[ Time: 0.0100s ][ Queries: 3 (0.0040s) ][ live ][ 343 ][ ThingOne ]
