Thanks everybody,
I gave up on the big bore motor because starter couldn't get past compression stroke.
Got a new used motor.... With its own problems.
I've got a nice healthy spark with new Stater and CDI
90 psi compression while cranking on the starter without any oil assist in the cylinder.
Everything I've seen says that is pretty much enough to get things started ? Also I've read that could be higher up around 130
I have sprayed ether into the intake, spritzed gasoline into the intake... It's almost like the spark is happening at the wrong time?
The motor shows no signs of being rebuilt
Anyone ever seen anything like this
