Greetings and hello,
I am new to this forum and I am requesting your help.
Recently purchased a 2009 Piaggio MP3 500 (VIN ZAPM610X395001306).
It seems to have mechanical problems.
It will start and idle smoothly for about 3 minutes and then die.
While running, using the throttle to increase the RPM, it will frequently but not always rev up to about 3,000 RPM.
At that point the idle speed will slowly deteriorate in fits and starts until it dies.
I suspicion the problem is with the throttle body \ ECU \ injector assembly .
I am looking for a compatible ODB diagnostic scanner (three pin connection) to help with diagnosis of these issues.
Please can you recommend an affordable compatible OBD scanner.
Many Thanks.
