whodatschrome wrote:
I've installed at least four of those gimeca kits on my own personal scooters. I've also had the cable operated (semi-hydraulic) setup for a bit. It still worked excellent, but i didn't like the looks or the design. You can totally start out with installing it as a semi-hydro, but (to me) it's well worth the additional $$$ to just convert the system over to full hydro. It takes some doing to adjust the semi-hydro's cable up correctly in order to get brake lever to feel good. Rather than spending the time doing that, i just make it a point to go full hydro. Expect to spend around $1000 for a full disc brake conversion.
Basicly the same experience for myself with multiple kits. A disk brake is a great upgrade, personally my favorite upgrade on any Vespa. Go full hydro and you'll be Super happy. Personally I think its actually less work to do full hydro, than to mess around with the semi set up. Its well worth the effort to do it from the start.
Once I installed a semi hydraulic setup on a P200. It was a survivor white paint, super low miles. So we did it semi-hydro, to keep the OG headset. Get it all set up, bleed the lines, which took hours... not joking... then adjust the cable. Then do it all over, because its not quite right. Finally get it all set up, go out for a test ride in the neighborhood. Feels pretty good, a bit spongey... feels tight... feels grabby... ohshiz... GRABS AND LOCKS UP!! Vespa on ground, Geek Lion over bars, damage not terrible... but not great. There was a tiny bit of air in the line that expanded with heat and locked up the front caliper. I ripped of the semi set up immediately and swapped to full hydro. Just do it
