Remembering that though the positive side of the starter relay is fed via the usual fuses, starter button and brake light switches, the negative side is fed from the ECU. So any poor grounding of the ECU or 'other things' upsetting it could cause the relay to chatter - so double check all the grounding, from the negative of the battery to frame, frame to engine, ECU connector, etc.
