'79 Vespa P125X
'79 Vespa P125X
What is the process for getting a master key for a 2012 Vespa LX 150 and approximate cost of doing so? All I have is one blue key.
Thanks in advance for your reply.
Landy89 wrote:
https://scooterpartsco.com/lx-150-keys-and-locks-c-3637_3646_3876/lock-set-for-vespa-piaggio-with-immobilizer-p-1203.html
You'd also need a new throttle body (or get your current one 'virginised'), so it gets expensive.
Far better to just clone your blue key: https://www.af1racing.com/AF1-KeyCloning-EXT-AF1-Racing-Key-Cloning-For-External-Cut-Keys
Now if you're worried that the key might get lost in the post - if that unlikely event did happen, you'd be no worse off that having to get the lockset and the ECU in the throttle body 'virginised'.
@abner_bjorn avatar
@abner_bjorn avatar
What are you after here? If you want a spare in case you lose the current key, they can clone you a duplicate off your blue key. That cost me $35 at Sportique. I store the OE blue key, and have been using the cloned key for close to two years now.
[ Time: 0.0092s ][ Queries: 3 (0.0017s) ][ live ][ 343 ][ ThingOne ]
