T5 Classic
T5 Classic
Hi Folks. My scoot has been running badly so I checked my timing. When I strobed it I found it's now static. It's not advancing or retarding when reved.
I have tried my spare CDI but it's still the same any ideas?
@chandlerman avatar
Innovator
336 Days Since Last Explosion
Innovator
@chandlerman avatar
The variable timing on ignitions is provided by the CDI, so if you swapped it for a static CDI, that would explain it.
If it's supposed to be variable, then your initial diagnosis is correct: your CDI is bad, but you have to replace it with a variable CDI.
Did you replace it with another Flytech CDI? And was it variable?
It's an interesting failure mode in any case.
@gickspeed avatar
@gickspeed avatar
You gotta have the worst luck.
[ Time: 0.0087s ][ Queries: 3 (0.0028s) ][ live ][ 343 ][ ThingOne ]
