Hello!!!
My keys have vanished. Time to get new ones made. I do indeed have my spare. What do I do?
2022 VESPA GTS 300
Posts: 486 Location: Pearl River, NY ' |
Hello!!!
My keys have vanished. Time to get new ones made. I do indeed have my spare. What do I do? |
Posts: 46114 Location: Pleasant Hill, CA |
Get your spare cloned. Either send it to AF1 Racing, or find a local auto locksmith that can clone it.
2022 VESPA GTS 300
Posts: 8843 Location: Batmania aka Melbourne, Aus |
Buy the key blank. Get any locksmith to copy the teeth. Then use the correct timing of brown, new blue, brown key sequence (explained in the workshop manual).
Done. |
SteelBytes wrote: Buy the key blank. Get any locksmith to copy the teeth. Then use the correct timing of brown, new blue, brown key sequence (explained in the workshop manual). Done. 2. program the key with the correct procedure 3. cut key by a locksmith Programming can (should) take place before the key is cut. Procedere for No. 2: ALL: Programming New Keys |
GermanGTSDriver wrote: 1. buy compatible blank key (depends on modell / year) 2. program the key with the correct procedure 3. cut key by a locksmith Programming can (should) take place before the key is cut. Procedere for No. 2: ALL: Programming New Keys It says: "Put the (first) blue key in the ignition, turn it to the on position (without starting the engine) and then turn it to the off position within 3 seconds." Seems impossible to do that with an uncut key? |
PeterCC wrote: I am a bit puzzled. How can you perform the key-programming if the key is not cut first? It says: "Put the (first) blue key in the ignition, turn it to the on position (without starting the engine) and then turn it to the off position within 3 seconds." Seems impossible to do that with an uncut key? 1. brown key/master into the lock 2a./2b. switch ON / OFF (leave master inserted!) 3. fold out chip from master 4. hold blue key upside down next to lock, so that the chip of the blue key is closer to the ignition lock than the unfolded chip of the master. 5a./5b. switch again ON / OFF (to learn a second blue key repeat steps 4 + 5a +5b with another blue blank) 6. retract the chip of the master key (hold the blue key(s) away from the lock) 7a/7b again ON/OFF 8. wait 30 seconds 9a./9b. test with chip of master key unfolded and chip of (first) blue key close to lock (switch ON/OFF) -> test again for second blue key (if programmed) For understanding: the brown master key stays in the lock during the whole procedure, with this key you do all locking operations. It depends only on which key the chip for the respective step is closer to the lock (brown/blue), so you save the re-inserting of the keys and can achieve the required speed. Method above can be done before the new blank gets cut at a locksmith, so you are sure it will work BEFORE you pay money for cutting!" ALL: Programming New Keys |
PeterCC wrote: OK, different procedure.
Positive
I will not be able to use it, since the BV came without the master key.
I did not know about master and other keys when I bought it. But it came with 3 "blue" keys, the first is the original black key, and the 2 others are just blue. And all 3 work. I should be allright unless I loose all 3, which is very unlikely. |
2022 VESPA GTS 300
