@jozzze2000 avatar
Vespa PK 50(75), PX80(139)
@jozzze2000 avatar
I have low milage (under 1k ) T5 LML that had to be pulled apart because there was oil seal leak on the clutch side.
I changed all the oil seals and put engine together and tested for air leak. I only did it with pressure.
I tested it with 11psi, pressure drops to 6psi in 8minutes.
Air leak is between engine block and cylinder. I used new original aluminum gasket.
Should I replace the gasket or....?
@gravelrash2004 avatar
P Series / LML / Motovespa
Ensure there is no excess gasket from the engine halves that could protrude and interfere with the base gasket of the cylinder. Then place a smear of gasket sealer on both sides of the Base gasket, torque the barrel to spec, let it set then pressure test again
That should sort it out
@jozzze2000 avatar
@jozzze2000 avatar
I removed excess gasket but I'll check again.
What kind of gasket sealer do you have in mind?
I favour a silicone based one.
Really depends on where in tbe world you are as to brand names.
Honda Bond - seems to be available worldwide
@jozzze2000 avatar
@jozzze2000 avatar
OK, thanks
[ Time: 0.0079s ][ Queries: 3 (0.0016s) ][ live ][ 343 ][ ThingOne ]
