Pk50 3 speed makes a odd noise when I spin the rear hub... Normal or will I have to investigate more?
https://youtube.com/shorts/c03O6tfqTtQ?si=tYZYvPHeHcLsKe_8
https://youtube.com/shorts/c03O6tfqTtQ?si=tYZYvPHeHcLsKe_8 |
Innovator
Posts: 12849 Location: Nashville 247 Days Since Last Explosion |
Innovator
Posts: 2450 Location: NYS |
Moto64 wrote: Cruciform has backed out. That used to be the old Indian beat. |
ditchdrift wrote: Dang... I guess I'll be having to convert to 4 speed sooner than I expected. It's just a stock 3 transfer 50, think I can keep riding? Seems to shift fine. |
Moto64 wrote: I'm sorry, I had the wrong cruciform in mind. If it does that while you are coasting I'd stop riding it and go inside and look. Rear Wheel Noise Seems like it's not too much of a concern? My scoot was owned by a restaurant for deliveries in Italy and has over 20k km on it. Seems like they took very good care of it tho. |
If you put torque on the shifter towards 1st or 2nd, is there a spot where the noise stops?
Moto64 wrote: If you put torque on the shifter towards 1st or 2nd, is there a spot where the noise stops? |
bodgemaster
Posts: 7826 Location: So Cal |
That's "cruciform clack".
Either the cruciform is worn, the gears need shimming, or the selector needs to be adjusted. Possibly all three.
Positive
SoCalGuy wrote: That's "cruciform clack". Either the cruciform is worn, the gears need shimming, or the selector needs to be adjusted. Possibly all three. |
Just checked and it's 4 'clicks' per revolution in either direction. So it sounds like it's something with the cross.
ditchdrift wrote: Just checked and it's 4 'clicks' per revolution in either direction. So it sounds like it's something with the cross. |
P Series / LML / Motovespa
Posts: 1484 Location: UK |
Moto64 wrote: Maybe the balls have worn grooves in the cross legs and made neutral sloppier (wider?) than it should be.
Positive
Gravelrash2004 wrote: Is it just me that snickered reading that statement... sounds almost like a double entendre
Positive
Posts: 5108 Location: Australa, Mate |
Posts: 1200 Location: York, PA (the intellectual center of the universe) |
ditchdrift wrote: Just checked and it's 4 'clicks' per revolution in either direction. So it sounds like it's something with the cross. ditchdrift wrote: No. I tried both ways and it drops into gear before the noise stops. I am looking forward to what you find. |
Moto64 wrote: Could be one leg hitting four slots or one slot catching four legs. The fact that it does the same thing it either direction is curious. ALso, listening to your video, it is odd that the rhythm is a pronounced 1-234,1-234,1-234. Does it play the same beat each way? But the noise goes away in all gears? I am looking forward to what you find. After the proma exhaust, boring the 16.12 out to a 16.16, the clutch is slipping something fierce. I think it will be time to pull the motor and kit it. I'll probably do the full Monty. Primary gears, 4 speed, full circle crank, 135-170 cylinder. Just trying to figure out how far I want to take it. I typically like doing mods in steps but can't really easily do that when you have to split the cases for each mod. |
