@jensenfish avatar
1963 VBB
@jensenfish avatar
1963 VBB
I own a 1964 VBB2. I am currently on points and want to upgrade to the Sport versus Road because we have some hills around town. I am correct in thinking that the Sport will help me get up the hills?
Ignition SIP PERFORMANCE by VAPE Road 12V AC
Ignition SIP PERFORMANCE by VAPE Sport 12V AC
I don't know what wiring harness, spark plug, or other upgrades I'll need with the new ignition.
Bulbs need to be 12V now, but is there anything else I am forgetting?
I will be buying everything at SIP.
Any help is much appreciated!
Switches will need to be…. Switched.
For sure the brake needs one not 100% on the handlebar one, but I'm pretty sure that also needs to be swapped out.
Harness
Bulbs
Switches
Ignition
I think that's all you need.
@grumpnut avatar
'58 VBA
@grumpnut avatar
'58 VBA
A better ignition does not make more horsepower.
A box exhaust will help that.
@gickspeed avatar
@gickspeed avatar
You will be better off with static timing.
@gravelrash2004 avatar
P Series / LML / Motovespa
Agreed. I have the vape variable timing setup in my 210 and my riding style doesn't make use of it. I'm going back to "static". If I rode it like I was on a race track, maybe the variable would help
@garncarz avatar
@garncarz avatar
Leave the ignition the way it is. Time it properly. Start with a SIP Road 2 exhaust with main jet bumped up by one size? Go from there. Opinions?
@grumpnut avatar
'58 VBA
@grumpnut avatar
'58 VBA
Well. I've moved past points and have no interest in going back.
@jensenfish avatar
1963 VBB
@jensenfish avatar
1963 VBB
A little context. I have had my scooter for 20 years. It has always been a pain to start. I live in Maine now, and the roads are super dark. I want to upgrade the ignition to help with the starts and brightness of the headlights.
Thanks so much for the info, everyone!
Grumpnut FridayMatinee
I was thinking more torque in lower gears with the variable timing. I am glad I asked. Thanks. I will go static.
https://www.sip-scootershop.com/en/product/ignition-sip-performance-by-vape-road-12v-ac-for-vespa-125-vna-vnb-gt-gtr-1-super-ts-1-150-vba-vbb-t4-gl-sprint-v-1-super-1_510061RA
I believe this is correct wiring harness:
https://www.sip-scootershop.com/en/product/wiring-loom-sip-premium-20-for-conversion-to-e-ignition-ducati-sip-performance-vape-ac-for-vespa-50-n-l-r-s-sr-ss-90-r-ss-100-125-pv-et3_86134210?usrc=wiring%20harness%20loom%20for%20Ignition%20SIP%20PERFORMANCE%20by%20VAPE%20Road%2012V%20AC
@gancarz
Is this what you are referring to?
https://www.sip-scootershop.com/en/product/racing-exhaust-sip-road-20-for-vespa-125-vna-ts-150-vba-sprint-px80-150-pe-lusso_24166200?usrc=sip%20road%20two%20exhaust
FridayMatinee
Yeah I can't figure out which light switch either.
I think this is the bulb:
https://www.sip-scootershop.com/en/product/bulb-12v-35-35w-socket-ba20d-headlight_57300000?usrc=12v%20bulbs
Is this the brake switch you are referring to?
https://www.sip-scootershop.com/en/product/brake-light-switch-premium-082775-086322-for-vespa-125-vnb1-150-vba-vbb1-vgla-b-gl-gs-vs4-5-160-gs-180-ss-0024700_18163710?usrc=vbb2%20brake%20switch%20shutter
Thanks so much for everyone's help!
@grumpnut avatar
'58 VBA
@grumpnut avatar
'58 VBA
You can go dc without a battery and then be able to use led bulbs with less issues than ac
@jensenfish avatar
1963 VBB
@jensenfish avatar
1963 VBB
I thought I needed AC if I didn't have a dedicated battery?
@jensenfish avatar
1963 VBB
@jensenfish avatar
1963 VBB
FridayMatinee
I had that one in my cart. I am not clear if it has a cut-off switch on the side or not. (turns off engine) Does it work the same way?
Thanks FM
Yeah on the right side is the kill button and the left side has another for the sip speedo control. I think they make ones without the speedo control button as well. Pretty sure I have that on my 62 Allstate.
The link I posted I have that switch on my 59 Allstate
@grumpnut avatar
'58 VBA
@grumpnut avatar
'58 VBA
I did too. But in fact that is not the case.
@moto64 avatar
@moto64 avatar
jensenfish wrote:
FridayMatinee
Thanks FM
Ignition would still be AC.
@jensenfish avatar
1963 VBB
@jensenfish avatar
1963 VBB
[ Time: 0.0183s ][ Queries: 3 (0.0064s) ][ live ][ 343 ][ ThingOne ]
