PX125E Lusso
PX125E Lusso
Hi everyone. I'm Thomas and am new here.
I'm having a charging issue, and I'm hoping someone can help me. I've installed the SIP performances ignition sport dc in my vespa px125 lusso 1999. I have followed the instructions to my best. It's seems to be operating fine at the first look, but there's maybe something wrong with the charging.
-With the lights turned off, I'm reading 13-14 volts on my multimeter, but only at 4000-6000 rpm.
-With the lights turned on, I'm reading maximum 12,3 volts, and only at high rpm.
I've measured that all the electrics pull 55 watts/4,5 amps at he battery when ingition's on with all the lights on, and engine off. I'm using an H4 halogen head lamp.
I have also measured that the new stator from the kit delivers up to 60-80 volts at the phase (black and blue wires)
-I have checked battery, its OK.
-I have measured the old harness for resistance, and all wires are reading 0.8 ohm. New and old.
I also found a some threads in this forum about dc conversion and sip ignition, with a wiring diagram. I've set it up just like that. Thanks.
In summary, it is charging, but very weakly. Is the kit not able to run a h4 bulb? Doesn't ad up with the 110 watts as labelled.
Where do I go from here? Faulty vape regulator?
Hope someone can help me.
Thanks in advance
Br Thomas
parallelogramerist
parallelogramerist
Thanks in advance
Br Thomas
Are you referring to the VAPE DC ignition kits that SIP sells?
@gickspeed avatar
@gickspeed avatar
for a test, run a cheater ground wire from rectifier to junction box/stator ground. Any change? do not use the wires in you harness for the ground on this one.
@mjrally avatar
@mjrally avatar
What wattage is the H4 headlight bulb?
@ray8 avatar
@ray8 avatar
^^ This.
Black from the junction box to the battery side is connected to chassis ground in the loom.
It needs to be direct from stator to the regulator/rectifier.
PX125E Lusso
PX125E Lusso
Thanks for your replies!
-Yes, its the Ignition SIP PERFORMANCE by VAPE Sport 12V DC
-The light bulb is 55 watts.
- Okay, i will try to connect the stator directly to the regulator. Thanks😊
PX125E Lusso
PX125E Lusso
That was the problem! I bypassed the harness with a wire directly to the regulator, and I'm now reading 3,8 volts even at idle speeds.
Thank you so much!
@gickspeed avatar
@gickspeed avatar
Thank you so much!
I would like to think it is more than 3.8V. Hope that is a typo.
@safis avatar
@safis avatar
FYI, that 55W bulb is too big and it will melt the headlight. Correct bulb is 12V-35/35W, P43T/HS1
[ Time: 0.0083s ][ Queries: 3 (0.0020s) ][ live ][ 343 ][ ThingOne ]
