Hi all,
I'm working on a custom wrap project for my 2014 Vespa GTS 300—which has been heavily modified for performance and aesthetics. I'm looking for a vinyl wrap or decal cutting template (preferably in .DXF, .SVG, or .AI format) that matches the panel contours of the 2014 GTS.
I've attached a reference image (see below) which shows the kind of vector layout I'm aiming to use—this might be for a newer model or a different trim, so I'm trying to confirm if anyone has the correct template for the 2014 frame.
If you've worked with wraps or know where to source these panel cut files (or if you have one you're willing to share), I'd be super grateful!
Thanks in advance—ride safe!
– Max (Singapore)
