New team member here with a new to me 2006 Vespa GTS 250ie.
My issue is that the headlight does not work on either low or high and also the horn. I've replace the headlight and checked all the fuses and they are intact, as far as I can tell. Is there a relay that's readily accessible that might be causing my issue?
Any help, hints, or solutions would be greatly appreciated.
