Hey all,
I have a v9b 100 smallie and I'm in the process of restoring it.
I'm by no means a pro and I barely understand what I'm doing, but slowly slowly (thanks to this amazing community) there's progress.
Currently I'm working on the stator and I can't for my life find an identical stator online or a diagram so I can understand the purpose of every coil and wire.
It looks similar to the primavera one but not exactly the same.
I already took it out, removed the old destroyed wires and soldered new silicone ones.
So I have 3 questions.
1. While I understand which is the black ground wire and which is the red one that goes to the spark, I'm not quite sure about the other 3 wires. Could someone provide some help?
[See picture attached]
2. How can I check the coils and condenser if they need changing? Do I check their resistance? how much should it be?
3. After I soldered the new wires, I was checking with my multimeter and noticed that the 5 wires that end up in the junction box have continuity between them.
Does that mean there's a short? Or is that normal since every coil is grounded?
P.s
I was riding this bike for over 10 years and it always had 2 issues. The horn would randomly make a faint noise and the engine would stall when hitting the rear brakes. Now I know why. All the insulation of the wires coming out of the stator and going into the junction box where completely stripped so everything was shorting. It's amazing that the bike was still running with the lights and everything.
