Hi there! I tried to unscrew the drain bolt and rounded the edges because i used a different wrench, not a tubular one. Is it possible for now to pump the oil through the dipstick hole? Like using an oil evac pump.
It's definitely possible, but if the bolt is definitely wasted, why not just use something like a vice grip to get it off and then replace the drain bolt with a new one? They're pretty inexpensive.
